ASUS A8R32-MVP Issues/Help.
cide_
I recently upgraded my A8V Deluxe to an A8R32-MVP for use with a new eVga 8800GTX single card.
well, all is fine and dandy. I decided to reuse my preexisting CPU and ram for the time being as I don't really find it nessisary to have anything faster and I have been running this 3000+ Venice core at 2.7ghz 24/7 for over a year on air/stock cooling.
Works fine still, so I reuse it.
Anyway, I flashed the new board to the latest firmware, And I even managed to get my old install of xp functional with this new board (That took awhile, but It works almost flawless because It takes me at least a week to get a clean installb ack to the way I like it.) I'll do a clean install later, but Acheiving my 2.7ghz with this new board I was able to do.
At around or ab it higher than the previous temps I had, Which is okay cause I used new thermal grease which wasnt as solid of a seal... But I am not able to OC the memory as well as before, or at all really.
I played around a bit at 2.7-2.9v and 1T/2T command with different settings (2.5/3/3/7, etc etc) and managed to acomplish a stable 2.7ghz problem free Overclock with the memory set to 133mhz in bios (effectivly 200mhz in CPUz 1t 2-2-2-5, The memory stock ratings) but this wasnt good enough for me so I played around more and acomplished a system that wouldnt post. All that would happen is you turn it on and hear the geforce 8800gtx fan go crazy like it initially does only for a few seconds, but endlessly... and no post.
I seated and cleared the cleartc jumper and rebooted and put my OC back to 2.7ghz,
but when I exit the CMOS setup the friggen thing wont post.
It posts _FINE_ from a cold state, it posts FINE from a reboot.
When I press reset, It DOES NOT POST.
What the heck is going on?
I also notice after the initial bios image, after it scans the silicon image controller card, It flashes the initial bios image again for a brief second -- BUT ITS CORRUPTED/BRIGHT Oranage yellowish colors --- That concerns me, Then it begins to load windows.
Theres no other problems, My OC is stable, the system is flawless, games are running like a dream, my sound is even less "dirty"t han with the previous mobo setup. Thigns sound cleaner, Ive disabled all LPT.serial. onboard audio, onboard lan2, and everything else I dont use.
I only have sata hard drives, I have 1 floppy and a plextor dual layer 16x dvdrw combo drive.
Is this an issue with the motherboard, Or could it be related to my PSU or something else?
Not being able to use the reset button is extremely annoying, and will eventually result in excess wear and tear on my HDD's when I have to reset the system cause of windows or soem other problem and insted of using reset, Cold boot.... You see what I mean.
Any help would be held in the most high of appreciation.
Nigel Kristian
Aka, Cide.
I'm still thinking about your reset not posting, but I wouldn't be worried about the corrupted colours of the ASUS startup screen. To my knowledge, if you have RAID enabled on the ULI SB the startup screen flashes a second time with corrupted colours. My A8R-MVP and my A8R32-MVP both did that. I can't tell you if it does it without RAID enabled as I have not used the ULI SB without RAID enabled.
Wow, Thank you so much for taking the time to reply to my message. I never thought something obscure like this would be answered.
Much appreciated,
So you say you get the corrupted colors too, Well thats a relief. What bothered me is that I didnt have it at first, when I overclocked. And I dont think I have it when its not overclocked, But I havnt checked that out recently, been busy doing a reinstall -- ugh. I did however alter some settings in the bios, And to my surprise, when I saved the changes and exited, The system actually posted. I have been crossing my fingers in hopes that this also resolved the reset button issue. I'm going to test it in about a few minutes. I'll post results.
I am not using raid at all though, I have 4 sata drives running in single mode on the ULI, and 1 Sata drive on the Silicon image controller, also in single mode.
I dont even use multiple partitions...
I dont know how you can enable/disable raid, Even, Perhaps you can share some more thoughts as you ponder further on the reset problem, Provided I have not resolved it yet. (I'll post an update shortly.. I promise!)
Thanks again bud.
