ASUS A8N-SLI RAID Problems
Nihsnek
Hi,
I had to buy a new motherboard since my old Asus A8N-E died. My HDs should still be fine, but I'm having issues configuring the raid/bios settings in order to get my 2 HDs to boot as one with Raid 0. My old board, a lot like the new one, just used nvraid and it was simple. This new one uses nvraid or Silicon raid controllers. I've tried both, and I keep getting a "hard disk error, please insert system disk" whenever I try to boot. I've checked and changed with my bios settings for a few hours, and tried re-making the raid setup about a billion times now. No luck.
Here's what I have at the moment:
HD plugged into red(silicon controller) sata port 1
HD plugged into red(silicon controller) sata port 2
Raid 0 setup using both drives as striped and bootable.
No IDE drives, floppy, cd-drive, dvd-drive, etc. at all plugged into mobo. Has anyone successfully done a raid setup with this board? If so, how?
So, you've setup the RAID0 array and installed an OS, but then can no longer boot after that? :confused:
