I've built a SSF system using the Antec Aria case. Its contents include:
AMD Athlon XP 2700+ Processor
Speeze 80mm Heatsink & Fan
ASUS KM400A mATX Motherboard
2x 512 PC2700 Memory
Standard 16x DVD-ROM
Seagate Barracuda 160GB HD
NVIDIA Geforce 6600GT
Included Antec PCI Slot Fan Installed
I'm running into some pretty extreme heating issues. I've read many threads both here and on other forums, as well as tech review sites, which note the Aria's poor ventilation, resulting in some high temperatures. However, most of the temperatures mentioned in these situations, when heavily tasking the CPU, average to be around 60°C.
However, I'm dealing with that temperature or higher at idle speeds. Swapping heatsinks and fans doesn't seem to make a difference, nor does removing the 6600GT. The center of the processor is properly coated with thermal gel and the heatsink is clean and secure, but this puppy cooks. On certain occasions, running a long AVI or playing a game has brought the CPU up to almost 75°C. The BIOS is set to shut down beyond that temperature, but this has yet to occur.
I'm aware AMD chips can sometimes run hot, AMD claiming 85°C is the max, but this thing is becoming a combination SSF system/portable space heater. Am I pretty much up poop's creek and need to a drill a damn hole in this thing? Keeping the right side panel off seems to help quite a bit, reducing the idle temperature to the mid-50's, lower to mid-60's when being tasked. I've seen the various modifications made to the case, most notably ventilation holes on the sides, and wondering if there are possibly other solutions to cooling this mofo down. If not, I'm curious if anyone has successfully cut a decent sized hole in a side panel using a hole saw.
Any advice, tips, or suggestions would be appreciated.
