Aria firewire problem
kenpomasta
Im putting together a system around the Aria case for a friend. The mobo he got didnt have any onboard firewire ports, and he wanted the front firewire on the case to be active. So i was looking around and found this card
Newegg
It has a USB and firewire header on it. So I bought it. however I find out that the header on teh PCI card only has 8 pins on it, and the Aria's front firewire has a 10 pin header cable. I was wondering if anyone knows If the 8 pin firewire header woudl be the same pin outs has the 10 pin.
thanks
Chris
Not sure if they are the same, but firewire is normally 6 or 4 pins...
