I am curious, since my last build was 4 years ago, do I still apply Arctic Silver 5 the same as I did with my single core as I would with my Core i7? With the single core, I only put a drop on the middle of the CPU (not more than the size of a pencil eraser) and put the heat sink on. But I read on one site that you should use more than that if you are using multiple cores. Any advice is appreciated.
