Sep 24, 2009 #1 W WPN1969 n00b Joined Aug 11, 2008 Messages 41 I replaced the battery a couple of weeks ago and around 5-6:00 A.M. it will beep and go to battery mode is this normal?
Sep 24, 2009 #2 engiNURD Fully [H] 2FA Joined Jul 17, 2006 Messages 21,828 no. did you buy the right battery? where did you buy the battery from?
Sep 24, 2009 #3 W WPN1969 n00b Joined Aug 11, 2008 Messages 41 enginurd said: no. did you buy the right battery? where did you buy the battery from? Click to expand... I bought batteries from a local store Altex. a CS rep paired batteries with UPS.
Sep 25, 2009 #4 S SockMan! 2[H]4U Joined Jul 31, 2004 Messages 2,187 It's normal if it happens once every 1-2 weeks for several seconds. That's just a self-test.
Sep 26, 2009 #5 W WPN1969 n00b Joined Aug 11, 2008 Messages 41 It happens about 2-3 times a day though.
Sep 26, 2009 #6 K keenan 2[H]4U Joined Aug 5, 2009 Messages 2,695 You could have poor line power quality. Mine will occasionally go on battery for a few seconds, and sometimes beeps when a vacuum cleaner or such is turned on.
