burritoincognito
- Sep 17, 2012
We have a client whose Barracuda 410 has been out of warranty for at least 6 months, and had its hard drive die.
They have a sister location with a 410 as well.
Does anyone know if there's a way to clone the hard drive of the working 410 onto a new hard drive, then do a factory reset to set it up from scratch, or maybe import a config file if one was saved?
Or, did they just get downgraded to a shitty $4000 1U server? I'm sure I could install something like untangle and get it to do some filtering without issue, or since it's actually an Athlon II X2 635e, which supports VT, I may just bump it to 8GB of RAM, throw in a pair of low profile drives (at least one, as I can fit that under the LAN/WAN ports), and turn it into an ESXi server to replace a few machines that are sitting around doing practically nothing (AV server, WSUS server, and whatever their door security system server is).
