dfarrales said:i'm seeing both single and dual antennas selling for wireless routers. is there an increase in performace for a dual antenna?
thanks,
Deo
ezkill said:No, the only main difference is that the dual antenna are more directional (i.e. you can point them in different directions to cover an area better). Be warned though, moving the antennas in a dual package might cause weak signals, than if you left them both sticking straight up. Also, I would recommend changing the antennas anyways to a 6dB gain antenna instead.
