ultimus666
- Jun 29, 2005
I'm a complete newb when it comes to case modding, so please bear with me. I have an Antec Sonata with a bunch of mods in mind I would like to do, although I've never really done any modding before so I have a bunch of questions.
1) I plan on adding a window to my Antec Sonata, would it be a good idea to add a fan in the window at the same time? I have 2 case fans (120mm) at the moment, but I know the Sonata doesn't have great airflow so I was planning on adding another fan. If this is a good idea, what size fan should I put in the window? And should it be intake or outtake? I have one of each at the moment. Plus my PSU that has and intake and outake fan.
2) What thickness plexiglass should I use for the window, or should I use Lexan or some other material? Keep in mind that I will probably be adding a fan.
3) Is there anywhere I can find a guide to installing a fan in a case window? I just want to make sure I don't mess it up.
4) I would like to add a fan controller to my case, to keep the noise at a minimum when I sleep or when I am not gaming. What fan controller do you recommend? I don't really know anything about fan controllers so I'd really appreciate the advice.
5) I plan on getting 3 UV reactive case fans to go in my case en lieu of my current ones, which make do you recommend? I want to make sure I get something that will not only look nice, but be relatively quiet while still moving a good amount of air, as I plan on overclocking. Are the Cooler Master UV reactive fans pretty good quality?
6) To get UV reactive parts to "react", can I use just any cold cathode light, or do I need a light that is actually UV? (dumb question, I know)
I think that about sums up everything I wanted to know. Please bear with me, I know some of the questions are laughable, but I just want to make sure my first modding project goes over smoothly. Thanks for any help you can give me.
