urbanlegend786
- Aug 11, 2005
SEALTeamSix said:It's probably just more costly than most of us are willing to shell out for a quality 500w... at that price, there are other solutions out there. But, it does look like a good design.
-SEAL
urbanlegend786 said:N0 one is interast in a phantom????500watts, fanless ULTRA silent
soulsaver_8229 said:you mean theres a better fanless psu than the phantom? id like to know which one is better if you dont mind linking
soulsaver_8229
SEALTeamSix said:Not to be rude, but the Phantom 500 actually does have a fan in it. What I'm referring to are $50-$80 name-brand PSU's, and then adding heatsinks and/or undervolting the fan. The Phantom is a nice PSU, no doubt, but it's also $165 shipped to start with. For my money, I'd buy a Sparkle/Fortron 530w for $75 and use a program like speedfan or add heatsinks and a resistor to the fan line for silence. Again, that's just my $0.02.
-SEAL
arentol said:...A true high-efficiency PSU like this one can ultimately end up completely making up the difference in just 1.5 to 2 years if you run your PC constantly, or in 3 to 4 years if you only run it 12 hours a day.
SEALTeamSix said:That's true, I hadn't thought about it in that way. Of course, even high-end systems only pull around 180 watts at load (that number is from page 5 of the same review you pulled the Phantom's effeciency specs from), so it would take longer to make up that difference. Still, it's something that can justify the cost from a long-term investment POV.
-SEAL
arentol said:You have a good point that actual consumption is lower than the number I used. I actually used a number closer to what you would see while gaming, but nobody games 24/7. So based on what I could find with a little research a PC with SLI 7800GTX's, a 4400+ X2 and otherwise "normal" stuff in (DVD-ROM, etc.) should pull around 190Watts idle and about 370 when playing games.
So it might take a while longer than I said to save you the money, but then again I was talking the $160 price.. At the ~$120 after rebate price it still should make the dough back eventually.
Chomp said:how does this compare to a ~500W Fortron?
