Only couple millimeters lower so if TRUE doesn't fit it's doubtfull that Noctua fits any better. (or any other highest end tower heatsink)Thanks for the input. I'm particularly interested in the Noctua U12P.
Even without that cable management space behind motherboard tray 20,5 cm width wouldn't have too much space.I've got the P190 which is almost the same case and even without the side fan installed the heat sink prevents me from using the side panel.
With retarding starting from front door who'll notice side?...if they want to move the fan back to the inside of the panel instead of the outside which is what they did with the 193. (Looks retarded in my opinion.)
Well... excluding depth it's still midi tower like P18x.
With retarding starting from front door who'll notice side?![]()
Just what kind case you're looking for and for what?Seems like every case I want has huge flaws. The $89 lian li that's a hot deal right now is completely unsuitable for air cooling, and the HAF 932 doesn't have air filters.
And even Lian Li has taken habit of making ugly front to many cases...True. The front door on back is ugly as hell on the P193. I don't like it at all.
And even Lian Li has taken habit of making ugly front to many cases...![]()
I prefer being able to access all areas of case without other components being in the way...no video card interference with installed hard disk drives.
