Antec p180 PSU question.
Klync
Okay, I shall have my p180 next week. Now, my question is. On my Enermax PSU, it has a 90 fun on the bottom. Now, on the p180, the PSU sit on the bottom. Do you guys shut the fan off on the PSU? Cuz, I dont see how its going suck up air, if the psu fan sit all the way at the bottom.
I think you can flip it over , and everything will still work.
If anyone knows for a fact that you cant, then correct me, but im 90% sure you can just flip it as long as the screws lineup.
The P180 has mounting holes to mount the PSU upside down or right side up, whichever is better for your particualr power supply.
displayimage.php
The PSU actually isn't on the bottom. I think it is equidistant from the bottom and top of the lower chamber. It sits suspended off of the bottom of the case, and has ample room to suck up air.
