Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I like it quite a bit... light as hell (my heatsink weighs more than the case, crazy 900-Us), good price, esp. with the PSU and straps... I LAN really often so it's very handy.
Although... installing my motherboard was a BITCH because the PSU is impossible to remove or install with anything in there, and I couldn't get my mobo+HSF in there with the PSU in... ending up having to bend the cross-bar to get the PSU back in after installing the heatsink.
To sum up, my only complaints:
-Mediocre airflow
-A bitch to work in (but it's a small case, so I wasn't expecting any better)
-Top and side panels are one piece, and they're riveted on, adding to the above statement
