Hi, i have tried searching but i couldn't really find out the answers to these two questions, and i think that some of you might be able to help me
Can you remove the stealth cdrom drive easily? or would u have to use a dremel or something, because I want to use my hard drive cooler in the 5.25 bay
Also, any idea if a spark 7+ thermatake will fit in the aria? I measured it and its about 70 mm
Thanks a lots guys
Thanks a lots guys
