Well tomorrow Ill be placing the order for my first SFF system! I am very excited to make the upgrade as I have been carefully planning this system for quite some time. I wanted to run my parts list by you guys to see if anyone can spot compatability issues or if anyone has some other suggestions. Thanks!
All from the egg,
CASE: ASPIRE X-QPACK-NW-BK/420 Black Aluminum 1.0 w/ ABS plastic front panel MicroATX Desktop Computer Case ATX 420W Power Supply
MOBO: Foxconn 6150K8MA-8EKRS Socket 939 NVIDIA GeForce 6150 Micro ATX AMD Motherboard
GPU: eVGA 256-P2-N529-AX Geforce 7800GTX 256MB GDDR3 PCI Express x16 Video Card
PSU: ENERMAX Liberty ELT500AWT ATX12V 500W Power Supply
CPU: AMD Athlon 64 X2 4400+ Toledo 1GHz FSB Socket 939 Dual Core Processor Model ADA4400CDBOX
RAM: CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model Twinx2048-3200c2pt
HDD: Western Digital Caviar SE16 WD4000KD 400GB 7200 RPM Serial ATA150 Hard Drive
DVD/RW: PLEXTOR Black IDE Slot Load DVD Burner Model PX-716AL/SW
CPU COOLER: ZALMAN CNPS7000B-Cu LED 2 Ball Blue LED Light Cooling Fan - Retail
OS: WinXP Pro x64 Edition
all for around $2k
hopefully with a x2 Dell 2405 soon to follow, was going to go for the Westinghouse but opted for 2 of these at the last minute.
Thanks in advance!
All from the egg,
all for around $2k
Thanks in advance!
