jonnyGURU
Technical Marketing Manager at Corsair Memory
- Apr 9, 2005
I don't see this one much in circulation, so I thought it'd make a good review.
The power supply is from ePower/PCMCIS (one in the same, right?) It's fanless and called the "450 Lion." Model # EP-450P5 L1."
I haven't hooked it up to the loader yet, but when installed in a PC it seemed to be fairly stable, but got wicked hot. The fan isn't supposed to turn on until the load is greater than 250W. The fan never turned on!
Maybe they should make it turn on if the load exceeds 250W OR the temps get over a certain number. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Unfortunately, the whole PC got hot too since there was no ambient heat exhausting through the PSU, but that's partially my fault. I'm sure I could buy a case and some case fans that would be a suitable alternative to relying on a power supply fan to exhaust heat.
The unit is made by Topower and offers a whole 28A on the 12V rail. It doesn't have a 24-pin connector or PCI-e, so I'm not sure who the target audience is supposed to be. Maybe they're discouraging installing it in a really powerful system because it'll overheat?
Anyways... Many truths will be exposed once I get the thing on the SunMoon... But for now, here's some pics:
This is the top of the PSU. Looks like any other Topower.
Here's the label. Note the cheese grater grills along the bottom of the PSU.
Here's the back. The button allows you to turn the fan on. Note the heatsink sticking out of the back. It looks like nothing more than a 60MM CPU heatsink....
...From the inside, you can see that the "CPU heatsink" isn't really part of the heatsinks the MOSFET's are attached to. It's "bolted" on to the other heatsinks.
Side shot with top off. Looks very Topowerish.
