my computer is a huge asshole.
When i turn it on, if it manages to turn on it freezes when it starts to load windows. and when i try to run windows in safe mode it often times doesn't even get that far and restarts. I have, however, managed to get it to give me a BSOD every now and then when i try to run windows in safe mode. it gives me the old "PFN_LIST_CORRUPT" error. I had this same problem a couple months ago and after trying a bunch of different memory configurations i just put it back to the same configuration it was in and for some reason it worked. Can anyone tell me what's going on, or what I should do? I tried moving the memory around a bunch, i tried each stick, none works any better than any other. should i try increasing the voltage? changing the timings? my ram is supposed to run at 2-2-2-5. what should i change it to if i do change the timings? any suggestions?
thanks in advance.
thanks in advance.
