Canadian 2.5RS
- Sep 12, 2006
I am planning my first WC setup and I just want to make sure that I am not missing anything (parts or otherwise). Any advice would be appreciated as well.
My perspective setup (in a TJ07 if it makes a difference):
I plan on running it pump>rad>CPU>NB>GPU>Fillport>pump (is this the way i should run it?)
Parts:
- Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
- D-TEK Customs Fuzion CPU Water Block S478/LGA775/S939/AM2/S754 1/2IN Barbs
- Swiftech MCR320 Quiet Power Water Cooling Radiator Black G1/4 Threaded
- Masterkleer Pvc Tubing 7/16IN ID 5/9IN OD 10 Feet
- Ek Water Blocks Full Coverage NVIDIA GeForce 8800 GTS GPU Block
- Danger Den Cooling System Fillport Black W/ Wrench
- Swiftech Adjustable Black Hose Clamps for 1/2IN Tubing (2 Pack x 6)
- Danger Den G1/4 to 1/2IN High Flow Barb Chrome Fittings (2 Pack)
- Tubing Adapter, 10-13mm, Pair (to join in the NB blcok in the Asus Blitz Formula or Maximux Formula Mobo)
- YATE LOON 120x120x20mm Case Fan - D12SM-12C Medium Speed (x 3 or should i get 6 and go with a push/pull setup?)
- Dangerden High Flow G 1/4 Fittings - 1/2" ( I think I only need one set of these for the rad)
- Poly Wye Fitting - 1/2" (to add the fillport to the loop)
- Some kind of water additive
Am I missing anything? Do I need a rad shroud? Can i mount the fans directly to the rad?
Oh yeah, This is for OCing a Q6600 on the above mentioned mobo(s). But I dont need to go crazy with the OC, just as much as i can. My goal is a quiet OC (quiet over OC though)![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks for the help.
Parts:
