I've been reading these and other forums extensively and am finally getting my head around a Freenas 8 build that I'd like to post here for comments and suggestions.
This is going to be a fairly high end NAS that will be used for home use. It will serve a variety of purposes including:
Case:
Norco 4224 (24 drive hot swap chassis): $400
http://www.newegg.com/Product/Product.aspx?Item=N82E16811219038
I won't be able to afford 24 drives now, but want the room for future expansion. Components for this server should be able to accomodate 24 drives (3TB, 6Gbps).
Motherboard:
Supermicro X8SI6-F: $270
http://www.supermicro.com/products/motherboard/Xeon3000/3400/X8SIE.cfm?IPMI=Y&TYP=SAS
Though it is limited in slots, I liked the built in 6Gbps SAS Controller and built in dual Intel NICs. Support for 32gb ECC RAM was also a bonus.
CPU:
Intel Xeon X3430 Lynnfield 2.4GHz 8MB L3 Cache LGA 1156 95W Quad-Core Server Processor: $205
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117226
Is this overkill or would an i3 suffice? Also, is it worth another $35 for the 2.5 ghz Xeon X3440 that includes Hyperthreading?
Memory:
16 GB (2x8gb) ECC REG DIMM: $160
http://www.amazon.com/Kingston-ValueRAM-1333MHz-Voltage-Desktop/dp/B004Z9Y2G0/ref=sr_1_7?s=electronics&ie=UTF8&qid=1322488607&sr=1-7
Going with ECC for that extra bit of safety and so that I can eventually upgrade to 32gb if necessary
SAS Expander:
Chenbro CK23601 SAS Expander: $330
http://www.provantage.com/chenbro-micom-ck23601~4CHEN11K.htm
Rather than go for 3 HBAs, I figured I'd use this SAS expander to handle the 24 drives as well as any external connections if ever needed. It doesn't seem like there would be any performance issues going with this route.
Power Supply:
CORSAIR Professional Series HX750750W: $150
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10440897&PID=3891137&SID=
Total cost without disks is about $1515 plus or minus tax and shipping. I'd like to save money if any of the above seems to be overkill, but I'm expecting this to last a long time and handle all my storage needs for years to come so I'm willing to spend extra if it means a more robust and stable environment.
So this would represent the brains of my NAS. I haven't thought too much yet about drives with the current price hikes. I'm thinking I'd use 6 drive RaidZ2 vdevs and add a vdev as needs require and budget allows. I'd perhaps pool 3 6-drive vdevs and then a 4th 6 drive pool for backups. But this will require more thought and planning. My first goal is to figure out hardware so that I can watch for deals as they come up.
Any comments / questions would be greatly appreciated!
- Media storage (pictures, videos, music)
- Documents
- Movies (DVD / Bluray rips)
- ESXi datastores for VMWare (using NTFS or iSCSI)
- ZFS Snapshots / Backups
Case:
Motherboard:
CPU:
Memory:
SAS Expander:
Power Supply:
