I'm running a home network behind a basic Linksys router (BEFSR41). All of my computers are connected to this router using cat 5 cable and rj45 connectors. Is this cable equivalent to 10BaseT? I've asked questions on this before, and I apologize for any redundancy. I'm still a little confused on the issue though. When you talk about 10Base5/2/T/F, this just relates to signalling, correct? Not quite physical layer, but layer 2 if we're talking about the OSI model? Do all of these 10Basex standards run on different physical cables, or can you intermix them? Could I potentially plug different types of cable (other than cat 5) into my Linksys router, as long as they're using rj45 connectors (at all, at the same time)? Can rj45 connectors be used on cable other than cat5?
Thanks ahead.
Thanks ahead.
