When I have to reboot a server (primarily Win2k8 on my network), I cannot RDP into the systems for about 5-10 minutes. You can log into the console just fine, just not RDP. If you do a netstat, you can see port 3389 is not even listening. On the client-side, the RDP session just sits at "Initiating remote connection..." for a few seconds, until it bombs out. It doesn't seem to matter if I allow any version of RDP, or restrict RDP to NLA sessions. After as early as 5 minutes, and as late as 15 minutes (after the server is fully booted up with a CTRL+ALT+DELETE prompt on the console), you can finally RDP into it. You can also do another netstat and see 3389 open.
I run all my servers in a Xen environment, but I'm pretty sure this issue has happened in the past, on physical platforms as well.
Any ideas?
Any ideas?
