An Idea for a case
Pont
this is just a idea as of now. well i have the hole thing built in my head just wonted to get your guys input i wont to take a Jerry Can and mod it to hold a pc then paint it to look like a WW2 version instead of the brite colored ones there
what you think
that would be pretty cool, exp, if you put a window in the side, and maybe added water cooling ( you could get a old ww2 style cantinia and use it as a resivor)
probly no window but that idea for the wawa is cool did not think of that thanks
Gshady said:
Maybe this could give you some inspiration. http://metku.net/modgallery/detail.php?id=2472
I thought I had seen it in this forum but a search did not warrant any results.
thanks man that does help alot since im going with a WW2 setup mine will be a little differnt which makes me feel better but seeing how tight a fit everything will be ill probly go with a micro atx board get one of those agp card adapters that will allow me to mount the card differnt(like in the batman begains mod) and one of those micro power supplys maybe use some Laptop hardware also
