I currently have an AMD64 3000+, Newcastle Core, running at stock speeds on stock cooling. Currently running at 44C idle, gets up to around 60C full load. My case temp is around 35C.
1. Are these temps too high? I am having some stability problems (see http://www.hardforum.com/showthread.php?t=922251 ), and feel like heat may be the issue.
2. If I were to get a new HSF, which one is a good one to get? The XP90 seems to get a lot of recommendations, but others are fine. Something that cools well and is quiet. Maybe even one that will let me overclock a bit. And where to buy from? Something not too expensive.
3. How difficult is it to remove the stock HSF and put on a new one? Do I have to change the locking clip on the motherboard? How do I clean out the thermal pad and put in Arctic Silver?
