AMD xp 2400 overclock settings
dajet24
I have a amd xp mp 2400 with a abit Nf7-s V2
runs at 10 x 200fsb with perfect 24 hour prime results.
havign a hell of a time getting it to play with 10.5 and 11 multi's
i haev it running 11.5 x 182 and it boots up fine and such. just wondering if anyoen has had any success running 11.5 x 200 or if there is a better suggested multi x fsb i should use for best performance?
10 x 213 is about where she stops at 10 multi before getting errors.
currently running with duel ddr pc 3200 ram ddr core 2.7 vcore 1.75
bios suggestions for voltage multi and fsb are appreciated thx.
Try giving the ram more volts, about 3.0v, if this doesnt work, just set it back. Also try upping the vcore to about 1.85 and see what you can get.
IMO you need to up the voltage but don't just toss it to 1.85 volts. Up it slowly as you need to. 11.5 x 200 won't work b/c you need the extra voltage probably.
dammit i tried to up it to 11.5 x 190 and it all went to hell.
would have a blue screen stop registry error right as you would enter windows.
i tried everything every single bios default etc cmos nothing fixes it wouldnt even let me repair windows without messing up.
right now iam trying to reinstall windows but iam not to hopefull i tried 3 different sticks of ram all with the same result wtf happend ?
any suggestions wellcome.
