The system is Deacon in the sig.
Now...Here's the temps and speeds different componets are set at.
Cpu @ 2750 (11x250) Vcore 1.525v (normal vcore for this speed?)
Mem @ 305.5 Mhz (cpu/9 and Vmem @ 2.1v O_O )
So I love the system @ the speed it is, 3 problems tho... i think the voltages are WAY too high on the 1)CPU and 2)RAM, and 3) I can't get the ram to run at the CPU/7 mark (DDR2-667) even tho it's DDR2-800 spec'd ram.
So my ram's running @ 305.5 when it should be 392.8.
In case you're wondering, System and CPU temps are 46C Idle (Ambient temp is 32C) and I've seen ithe CPU peak @ 58C
Edit: Also HTT is set to 400
Help?
Help?
