I'm wanting to convert my system to a water cooled setup as my next major upgrade for my system. Only problem is the system I want to create sounds a bit... excessive when compared to the average...
My background is I spent 6 years in the navy as a nuclear reactor operator so they gave me a lot of engineering training on industrial cooling systems, so I'm looking at building my computer cooling system from a perspective of overkill = good.
Here's what I envision:
Reservoir as high in the case as I can get it with at least 3 inputs and 2 outputs. The 2 outputs would go down to 1 (likely variable speed) pump each, providing good NPSH for both pumps. The pumps would feed 2 separate radiators, however there would be a cross over between the radiators and the pumps to provide cross flow in case of pump failure/imbalance to still utilize both radiators. Both radiators would feed opposite ends of a 2:3 manifold where the coolant would be diverted along 3 paths, CPU, GPU(s), and Other (NB/SB/Mosfet/RAM/etc...) I envision the CPU would have the largest ID tubing (1/2in, with the other line having the smallest (3/8in), and GPU I haven't decided, maybe 1/2 maybe 3/8, depending if I went dual GPU or not. Then each of the 3 lines would connect back to the inputs on the reservoir.
Pros:
Cons:
I'm not too worried about the expense part since the increased expense pieces are reusable in future systems where fixed cost parts like GPU and MB cooling blocks may require replacement anyway. As far as leaks go I figure I can make the system tight and use water substitute that's non conductive.
What do you think? Too much, or just might work?
Pros:
- Redundant pumps, if one fails the system wouldn't necessarily fry itself in a hurry
- Multiple flow paths for higher total system flow from both pumps
- Minimizes problem of water temp rise across multiple components reducing system effectiveness.
Cons:
- Expensive, requires 2x pumps and radiators plus additional tubing and connectors.
- More tubing = more leak potential
