BrainEater
- Jul 21, 2004
My friends and I have been LANning for years.....slowly but surely , we've been upgrading our network.
At this time , we are just finishing our transition to a full gigabit network.We currently run an SMC 8524T 24 port Gigabit switch. (24 port version of this one.)
Within a couple weeks , we'll also be buying an SMC 8612T Tigerswitch.
Here's the issue :
The network topology will be as follows ;
The 24 port switch will be clients only.It'll be connected to the tigerswitch which will host the uplink/servers.
It's the connection between the two switches I'm concerned about.Now , the tigerswitch , being a fully managed L2 switch supports port trunking/load balancing between up to 4 ports,using the Cisco etherchannel spec....As far as I know the 24 port does not.(still trying to get through to smc)
I'd really like to run a pair of cat6's between the two switches , as the traffic could get pretty heavy , but I'm unsure If I'll gain any benefits without the port trunking enabled.
Is it possible to achieve this kind of load balancing with only 1 switch being managed / trunking capable ?
Any suggestions ?
Here's the issue :
Any suggestions ?
