Alright, my hardware
Whitebread
Here's the list, tell me what you think
Opteron 165--will probably overclock
Asus A8n-E
Asus Radeon X800--will flash to higher speeds
Antec SmartPower 2.0 SP-500
G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400
Creative Sound Blaster Audigy2 ZS GAMER
Gateway Widescreen LCD monitor
Some 17 inch LCD to use as second monitor
Will I be able to use the 2 front USB ports on that antec case with that Asus mobo?
Those are just the basics. Comments are welcome. Thanks
Asus A8n-E
I'm not sure what Antec case your talking about, but I dont see why you wont be able to use the usb ports.
Nice setup by the way
I forgot to list the case, but someone else also said that I shouldn't have a problem. Thanks!
