stealthy123
- Feb 4, 2005
I am tweaking my itx system and was wondering if I took my cpu heatsink fan off and instead put a 120mm fan that not only blows on the heatsink but will essentially blow over the entire mobo.
Aren't some cpu coolers dependent on a certain air pressure to work right? I am using the stock llano amd cooler which is just a solid aluminum core with fins coming out, kinda like the old thermoengine coolers minus the copper core. Looking at it, I assume it's not dependent on pressure because of how much space there is between the fins.
I am replacing it with the old am2+ stock amd cooler, and it has a much more dense fin structure so I am concerned it needs the fan right up on it to achieve the air pressure needed to work correctly.
Does anyone know of an article that explains air pressure as it relates to heatsink performace? I know all about pressure inside the case, but I need an article only dealing with heatsinks.
Of course if someone wants to just tell me about it, and explain whether my idea is viable, or if I am confused, I would appreciate it.
