morpheus9394
- May 8, 2002
I currently have 6 80mm YS-Tech case fans installed on my case, Two on the side panel, two on the top panel, one on the front and one of the back.
I also have an 80mm YS-Tech fan on my Thermaltake SLK-948U heakshink and I am fairly happy with the result.
My temps average 50c for the CPU and about 28-35c for the system, depending on the weather.
I am overclocking both my CPU and my 9800 quite heavily so good airflow is very important.
I would like to increase airflow by getting better fans with higher CFM ratings but I also want to reduce the noise level of the PC, so it doesn't sounds like I have a Jet Plane in my house.
Any suggestions?
Any suggestions?
