catkicker
- Mar 30, 2005
Don't know if this is extreme cooling.
I lucked out in the RMA process with AMD they replaced my 3200+ Newcastle with a 3700+ Clawhammer :nod: So I'm getting ready to setup my UT nF3 250Gb rig again but this time on air. Had been kicking sround some ideas about air cooling when I stumbled upon this unit at a ford automotive plant I'm working at. It's a airconditioning unit designed for cooling computer racks/ pannels/ enclosures in hot enviorments. I could not find a pic of the exact model but heres the basic design and specs.
Series Side Mount unit
cooling 2000, 586 BTU @ 60 Hz
This unit is roughly about the same size as a typical home computer tower. It's designed to provide VERY cold air to the case/enclosure without any moisture(Dry very cold air). It can not be mounted directly to my case but with some simple ducting I can have the unit setup to blow the cool air into the bottom of my Cheiftec matrix case at the bottom rear exhaust fan and the the other duct from the unit will enter the case below the PSU.
Problem is I'm working out of town for the next 3 months so this project will have to wait for now.
the main draw back is noise it has 2 fans moving 220CFM of air at 80db
I can replace those fans with these Deltas
http://www.sidewindercomputers.com/de12tfexhisp.html
65db x 2 beats the hell out of 80db x 2 .
It looks very much like the box on the right(Astek case/server cooling unit)
http://www.asetek.com/default.asp?s...=sideid&myvalue=14&contentSection=2&menuID=-1.
