AGP output problems
Howdy all. Was wondering if anyone could offer some advice...
Just received my order for my tax season present to myself. Included in it was a DFI Lanparty II Ultra B Motherboard. I'm using my existing video card (ATI Radeon 9700 pro). I put the card in and was getting no signal to the monitor. I took the card out and re-seated it (just in case) and that made no difference. I tested the card on another board to make sure I didn't fry it. Worked there. I tested the (also new) monitor and that works fine. I cleared the CMOS on the motherboard, all to no avail. Anyone have any other suggestions before I set up an RMA with newegg?
Thanks for any advice.
~TF
Even if it was a settings issue, you should at least get video out on post. I'd RMA ASAP!
