Again with the Random lockups and reboot...
aliensRreal
Not too long ago I had a problem with my computer locking up. I tracked the problem down to the mobo and now I am getting a similar problem, just not as often. On my other motherboard I flashed the BIOS, with this I have done NOTHING to mess with it.
At one point I thought it was my XP due to some issues I had during that install. After a reformat and a month or so later it started happening again. I have run AVG, spybot, adaware, advanced windows care, and so on. I haven't got Spysweeper on my system right now, but I do have a license. Should I install it and give that a go?
I checked the event viewer when ti happened this morning and this is what happened right before my crash (that just rebooted the machine)
Event Info: Guide creation error.
Process: DefaultDomain
Object Name: Media Center Guide
Just now the computer froze and left no events in the log. Anybody know what the heck is going on here?
EDIT: Would be possible iTunes is crashing the computer? I think both times today it happened iTunes was open and playing music.
a few more specifics are needed... what are your system specs, and was there a bsod? if so, what was the error? if not, did it restart itself? if so, turn that feature off.
Windows key + pause/break >> advanced >> startup and recovery settings >> system failure automatically restart
Ok, I just ran some Diagnostics
Memtest came up nothing after 45 minutes
Processor seems to be fine. I ran orthos for 20 minutes or so with no problems
Ran a hdd program and it found nothing.
As for the BSOD and all that. There is no BSOD or error. Sometimes the computer will reboot itself sometimes it just locks up. When it reboots itself an error report is made in the event log but when it freezes and I have to turn it off no events are made.
After talking with a friend of mine, I just realized I installed some Windows updates not to long ago and some failed. I will go back and see what worked, what didn't, and go from there.
I forgot the specs
E6400 Core 2 Duo
2 gigs Corsair RAM
Gigabyte 965p-ds3
550w Rosewill PSU (I know I know, I hear constantly how bad it is...)
EVGA 7600GT
Audigy 2 ZS Platinum
250gb WD SATA 3
45min is NOT enough for 2GB of ram. Anyhow, try an older restore point.
