Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hrmm, I was searching though a local store and I found this cool looking HS/F Combo... Aerocool High Tower CPU Cooler, It says it's rated up to 3600+ and you can put 2 80mm fans on it.
I saw it in a store a long time back aswell. The only problem I could drum up is the weight of the thing. It's going to stress the mobo, unless it's a desktop horizontal system, then it'll be all good.
