There's a script over at auto-it forums (auto-it is a script language for windows) that allows you to enable Aero glass effects on programs that usually don't have it. It's at: http://www.autoitscript.com/forum/index.php?showtopic=94763&view=findpost&p=757610
Right now it works on cmd.exe, powershell.exe, and a program called notepad2.exe which is basically just a simple text editor like Notepad. The reason it only works on those programs is because there are some limitation; you must be able to change the colors to white text on a black background, and some programs use the wrong icons/api so their icons look washed out, cmd.exe, powershell.exe and notepad2.exe work and the script enables aero glass in them, however. A more thorough explanation can be found by reading the whole thread linked above. Highly recommended. Screenshot: http://img691.imageshack.us/img691/9906/glasson.jpg (btw, you can't have 'glowing text' so to compensate you should use a darker color intensity in windows aero settings)
