BoyBlunder
- Nov 10, 2003
Alright, well I've saved up enough cash to get myself a Shuttle. I already have some basic components (XP 2400+, HDD, DVD-RW, Radeon 9700 pro), and I just need some advice as to what kind of components I should use...
So far I have this:
Memory: Corsair XMS Extreme Memory Speed Series, Low Latency (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-2700 with Platinum Silver Heat Spreader - Retail
and the Shuttle itself:
Shuttle Black XPC Barebone System for Socket A at 266/333MHz FSB AMD CPU, Model SN41G2B
Now, I don't know if I need all of that RAM in there. It's expensive as hell ($235) and to tell you the truth, I won't be overclocking it at all (I'm afraid the Shuttle will melt with the HEAT!!). Anyway, I have 1GB of RAM already in my desktop (2x 256 Kingston @ 333, and 512 Samsung @ 333). So what should I do about this RAM issue? Should I keep the Corsair, go with something cheaper or use mine?
Thanks.
P@
**edit: I play a lot of games, but I don't do any sort of CAD work or Photoshop work...I don't know if that would help in anyone giving me advice. THX.
So far I have this:
Thanks.
P@
