Good morning,
Im purchasing a 26 or 27 inch LCD tv soon for primary use as an computer monitor (games, movies, some text work). I understand that the 1366x768 resolution is rather low, but i think i can deal with it, ill just crank up the antialiasing. I have some questions however.
This is my primary choice at the moment:
http://www.buydig.com/shop/product.aspx?sku=SYNLT26HVX#description
#1) The contrast ratio is listed as Contrast Ratio: 1600:1(dynamic), however, on the official spec sheet, it says 750:1. Which one is it, and what do they mean by dynamic.
#2) Will i be able to run it natively at 1366 x 768 through my SLI'd 7800GTs (i know ill have to add a custom res)
#3) Am i looking at the wrong tv. ive also considered several others, here is what i need
*DVI
*1366x768 (1280 x whatever just seems a bit too big, the extra 100 pixels help)
*Good for PC usage
*No ghosting (this is subjective as well, i see no ghosting on my 12ms 17inch lcd, so anything below 12ms is fine for me)
*650 dollars or under (approximately
*Decent vertical viewing angles
The other tv's i was considering were the
Syntax Olevia LT27HVX
ViewSonic's N2750w
Any others that people know of would be greatly appreciated.
My main problem is that specs are listed differently everywhere so i dont know what to believe.
*DVI
*Good for PC usage
ViewSonic's N2750w
