First off I will be honest and say I did not perform a search just yet. Promise I will as soon as I close this but I have been reading a lot and nothing really addressed these ?'s Second anyone reading this, listen to these guys/gals, they know their stuff. I have my rig all installed and WC is up and running just fine. Long story short I got the TT Bigwater system when I purchased my new rig a month ago. I found out the pump would not be strong enough with my setup so I pretty much scraped it and got a custom system the next day before my stuff arrived. Out of the Bigwater I used the CPU block and the RAD/Fan. After I got my system nice and stable, wire managed, cleaned up, etc... the best I can pull are avg. temps.
? 1 if I swap my CPU block to a DD TDX block and get a DD 120mm Black Ice Extreme with Panaflow fan do you think I could see better temps or not going to help? I figure the CPU and RAD are flow restricted as I had 2 TT Rads earlier and no change in temp except the system dropped from 41C to 34 - 35 because it is not pushing hot air into the system.
Current Temps right now
CPU 40C
System 34C (house is sitting at 70F)
GPU 55C
? 2 I have a DD NV68. Are you supposed to use the provide AS Ceramique on the GPU because I used AS5 on it and as far as I can tell the block is on as it is supposed to be. I can redo if that would help but really don't want to if it is not the problem.
WC setup is Swiftech MCP650 - TT RAD - TTCPU block - DDNV68 -- Single 5 1/2 res - pump. Tubing is 3/8 ID all the way around except from res to pump with is 1/2 ID per swiftech saying it needed that. If you need more info let me know and thanks for reading and your help
CPU 40C
GPU 55C
