I think your in the wrong section bud. Check out "Overclocking & Cooling"![]()
What is cooling your video card now? You could add more case fans to your case, but that will only do so much and you likely won't notice a great increase in performance.
If you are using the stock cooler on your video card, your best option would be to remove it and buy an aftermarket cooler for your card that is mounted directly on it.
Definatly pick up a new cooler for the card. If you have a gtx you have limited options, either the arctic cooling extreme cooler or the thermalright hr-03 with a 120mm fan on it.
If you want, watercooling will do wonders, but for a gtx witl cost $150+
