Greetings...
I am building a hybrid Koolance/DIY H20 system and have come down to needing some fan controller ideas. I have designed in the Innovatek in-the-coolant sensor and will be using a total of five (5) sensors and also need to watch/change at least two (2) different fans. If your interested you can see what I'm up to at http://www.hardforum.com/showthread.php?t=865055
I have looked at some of the less expensive units, but they seem to lack programs or workability. I want to see on the display my CPU and H20temps (selectable) and I also want to keep logs that I can export easily to Excel. My choices seem to be limited to the Aquaaero and the Innovatek units. Which one of these systems will do me right? BTW, price is a secondary consideration.
What has been the experience of the group in regards to the Windows software supplied with the Aquaero and Fan-O-Matic. Anyone know about the Fan-O-Matic Pro?
If you know of something better I am all ears
