Does it give any sort of explanation? Or just "Sorry bud, I can't import these"?
File formats supported for import
Adobe Premiere Pro can import a number of video and audio formats. It also supports 10‑bit color depth, necessary for editing standard and high‑definition footage.
File format support is provided by plug-in software modules. Most of these software modules are installed automatically with Adobe Premiere Pro.
Supported video and animation file formats
Animated GIF (GIF)
DV-AVI (AVI)
Filmstrip (FLM) (Windows only)
Microsoft AVI Type 1 and Type 2 (AVI) (Windows only)
MPEG-1, MPEG-2 (MPEG, MPE, MPG, M2V)
M2T
Netshow (ASF) (Windows only)
QuickTime (MOV)
Sony VDU File Format Importer (DLX) (Windows only)
Windows Media Video (WMV) (Windows only)
Note: Type 1 AVI clips must be rendered before they can be previewed from a DV device. To render a Type 1 AVI clip, add it to a sequence in a DV project, and build a preview file of that section of the Timeline panel.
See if you can get a converter to swap them to a different format first, then bring them into Premiere.
