Adding fans to a case
GregMior
I'm just curious how you can add more fans to a case with a regular power supply.
My power supply only has four 4-pin power connectors and i use one for cd-rom, one for HDD and one for video card, how can I run more than one extra case fan with only one connection left?
Thanks
Lots of fans come with pass through connectors which means you plug them into a connector and it let's you plug the end of that connector into something else.
Exactly. If you've never really walked down that path before, it means that the fan has like a 4-pin (molex) splitter. So you have your Fan's plug which is male, and an additional Female plug if you need something else plugged in or vice versa.
