Adding a separate drive to a comp with two Raid 0 drives...
Toby
I have two 150gig drives set up in Raid 0... but... I need more space! - is it possible to add a third drive to use as storage, separate from the Raid?
Amen,
Toby
I plugged it into an open slot, but it wasn't detected. I think the raid was on ports 0 and 2, and I plugged the new drive into port 1.
I tried scanning for new hardware changes, but nothing was detected. But it's definitely possible?
Thanks for the responses btw!
Raid 0 is the one where the content is NOT duplicated, right? They both run together, and if one crashes, the other one does too or some such?
The drive still isn't being detected, should I move some of the pins from their default location?
Sincerely Word,
Toby
Is it being detected in the bios ?
If it is then it needs to be formated before Windoze can see it.
Right click "my computer" -> manage -> disk management -> format from there.
If its not then try a different SATA port on your mobo.
Luck ......... :D
RAID 0 is where two drives look like one drive to the system. If one breaks down, the other will be fine, but all the data will be lost, thus you will need to back up your data on an external drive. As for the formatting, as he said ^^^:D
Woohoo! In BIOS port 3 was set to Off, so I just... moved it to on. Then I went to management and it showed up, now it's formatting. (maybe I should've quick-formatted...?)
Is there any way to assign it a drive letter that's currently being used by something else?
As long as it not the system or boot drive letters then yes.
In "drive management" right click on the volume -> chamge drive letter & path.
Just move the drive on the letter you want to a different one.
Then move the drive to the letter you want.
Luck ........... :D
