smurfless1
- Jul 30, 2010
Running an ESXi server with a supported Adaptec 5085, and every time one of my disks does something odd (which you can't monitor or log, incidentally), the arrays go offline immediately, or the server hard reboots. I checked the support list for the hard disks in the array, and they are supported.
Now, call me stupid, but isn't the point of having a RAID5 set up is that if the disk goes offline, nothing happens? You get the sound and replace the drive and everything stays up?
Is there a way to capture a log of events or something from the card when you can't run Adaptec's software?
