Alright first off I've never used Citrix so my knowledge on that software is limited to the manuals and such.
First question - Does Active Directory run through Citrix? I'm going to guess yes....power the computer on, connect to the Citrix network and Active Directory through the Citrix connection. All the Active Directory content is secured through the Citrix connection.
Second question - If Active Directory is not going through Citrix, how much bandwidth would it use if it's conenction is through a 2 mbps WAN connection. Can you throttle the bandwidth that AD uses, like a certain percentage of the connection?
Third question - If the answer to question #1 is Yes, will Citrix throttle the AD bandwidth?
I'm doing research to see what an impact AD would be on a 200 machine network spread across 14 remote locations (all about 2 mbps lines).
google isn't helping me too much on this one. I've been searching for the last 4 hours and I've found some stuff but not the answer I'm looking for. I'm hoping that someone out there has run into this question before and can help me with an answer.
Thanks.
Thanks.
