ThreeDee
- Sep 5, 2001
I got this computer from a friend of mine who has a teenage son and daughter that like to click on anything and everything ...
going thru in safe mode as Administrator I was trying to clean out temp folders in each accounts local settings folder but the daughters account says access denied
so I tried to change permissions on her user folder and then I was able to get into it and see all the other folders but I cant get into nor change permissions on any of the sub folders and get the
Error Applying Security:
an error occurred applying security information to:
\??\C:\Documents and Settings\Jennifer
Access is Denied
When I go to inherit permissions , and "unknow user" shows up as well
I did a search on google for \??\C:\ but only c programming info
How can I get into Jennifers folder and retrieve her pictures and stuff?
Once I get all the data backed up , I will probably just reformat and reinstall windows from scratch then for them..
![](http://www.hardfolding.com/ftag1.php/mem/533.png)
Access is Denied
