AC Flowmeter / Help ..
M a d c o w
Hey there everyone ...
Im pretty much done with my project w/AC. First off i got my tubemeter to work however its not connected to the Aquaero anymore for some reason its not detecting it. So i ended up connecting it to the mobo, which picked up right away and gave me actual readings. Not sure if the aquabus slot is faulty. Gonna check with Sharka.
Anyhow my dilema now is im not sure if my flowmeter is working correctly. Although h2o is flowing through but its just not reading it through my Aquaero / Aquasuite. Once you got this flowmeter connected to the Aquaero does it automatically detect the h2o flow ? Or is there something i gotta do proper settings in the Aquasuite. I got the most updated firmware ( 4.09a OS 2.03 ) Whats the trick on this ? Does it need to be mounted in a specific way and does it need to be in a specific area in the loop. Here's the flowmeter. Feel free to any suggestions.
Got everything hooked up correctly? Please note that the # 1 pins on the Aquaero are not what you would normally think. Are you using the latest Aquasuite software? Did you try enabling the function through the Aquaero display? Did you read the Aquaero manual?
Just an fyi....I drilled out my AC flowmeter to more closely match the tubing size.
