psshhhh..... not at all. go and use a $150 19" crt than use a $300 19", the difference is amazing.Originally posted by M4d-K10wN
I thought all CRT's were pretty much equal. So.. what makes a monitor great?
yea 1024x768 is a bit of an underkill. you could do 1600x1200@100hz+ on a good monitor without any problems and 2048x1536@68hzAnd also, a lot more desktop space! I think you'll be using 1154 x 862 (or whatever the heck it is) or 1280x960 or something with that monitor
Originally posted by jamestime88
psshhhh..... not at all. go and use a $150 19" crt than use a $300 $19, the difference is amazing.
Yeah, the LG i'm getting can do 1600x1200@85hz, but everything would be WAY too small then...
