Im about to order the following and just want to make sure everything is going to be compatible.
AMD ATHLON 64 3200+ PROCESSOR S939 2.0GHZ 512KB L2 CACHE RETAIL BOX
DFI LANPARTY UT NF4 ULTRA-D MOTHERBOARD ATX S939 NFORCE4 ULTRA DDR 2PCI-E16 PCI-E4 PCI-E1 2PCI ..
ANTEC SONATA QUIET CHASSIS ATX 3X5.25 6X3.5 PIANO BLACK 380W TRUEPOWER
SEAGATE BARRACUDA 7200.7 80GB HARD DRIVE ATA/100 8.5MS 7200
LEADTEK WINFAST PX6600GT TDH 128MB DDR3 PCI-E VGA
CORSAIR TWINX1024-3200 PC3200 2X512MB DDR CAS2 SILVER HEAT SPREADER
I'm right up to what I wanted to spend, BUT what would you guys suggest I change for the better? Is this a good choice for ram? I dont know much about ram and most likely wont overclock it.. should I save some money and go the value select route?
Thanks in advance..
-Foz
Thanks in advance..
-Foz
