Abit IC7 problem with bios...this is weird
sparks
After installing a new cpu cooler I booted up my system and it refused to hold any cpu settings.
I reset the cmos and tried again..nope
this is the latest 28 bios so I thought ok maybe its screwed or something so I reflashed with 27 bios. Same thing.
no matter what I do, any cpu settings are ignored. set the fsb to 220 or 240 and save bios comes up and shows 200 fsb.
I can go into windows fine and even tried clockgen and it will change the fsb and works fine but on reboot I am back to 200.
Nothing will save in the bios.
any one have any idea why?
thanks for any help
sparks
is it just the FSB settings or ALL of the settings?
all of the settings (like memory timings, boot order, etc) = bad battery
just FSB settings = overclock failure or failure to recognize CPU so it restores to default FSB or other issue
You didn't mention what CPU you have. And did you try 202-205Mhz, or something that should definitely work at default voltage.
Do you have the CPU fan hooked up to the 3 pin CPU header ?
Its just the fsb settings that are not being stored.
All other bios settings are there.
I set it to skip any boot errors.
But you set it and it reboots and it comes up 200 fsb no matter what
your fsb settings are set at.
Have the lead in the cpu header and it shows the fan rpm ok.
sparks
Have you tried re-flashing the board with the latest bios? (even if it already has the most recent one?) I had that same kind of issue happen with an P5ND2-SLi and a pentium D 830...reflash and it worked great.
